-   -   How do gasoline, coolant, and engine oil stains from concrete driveway? (https://www.revscene.net/forums/715213-how-do-gasoline-coolant-engine-oil-stains-concrete-driveway.html)
BIC_BAWS 08-16-2018 10:44 AM
Error made in title: How do you remove gasoline, coolant, and engine oil stains from concrete driveway?
I'm using a 1600psi electric pressure washer and apparently just water doesn't work. . I tried using coca-cola, iron-off, and break clean. Break clean works wonders for the engine oil stains, but its not cost effective.
My strata is pretty lenient, but I think that gasoline stain was the last straw. The gasoline stain is the worst.
Another thread regarding prepping concrete floors used Muriatic Acid, and I might pick that up. Only issue is that it stains yellow. Any other recommendations?
Thanks!
Bouncing Bettys 08-16-2018 11:06 AM
Paint Thinner.
vitaminG 08-16-2018 01:14 PM
Try some super clean or other degreaser. Also try removing bmw to reduce oil stains
unit 08-16-2018 01:22 PM
be careful using paint thinner on your driveway... if it's asphalt it may damage it.
keifun 08-16-2018 01:46 PM
I heard coca cola works Due to the carbonic and sulphuric acid in the soda
Surprised you said it doesn't work . Maybe need some more elbow grease .
Try acetone ?
nismodrifter 08-16-2018 01:52 PM
Powdered laundry soap, stiff broom, water. scrub scrub scrub scrub. let dry, pour kitty litter on it, rub the kitty litter in with your feet, let it sit for a day or two. repeat.
Badhobz 08-16-2018 02:05 PM
If nothing works just spot paint over the stains with some all weather matching grey paint.
Excelsis 08-16-2018 04:00 PM
degreaser and hot pressure washer optimally.. or 4000 psi regular pressure washer - 1600 psi isn't enough.
yray 08-16-2018 05:39 PM
turtlewax car wash always took oil stains out from concrete
just pour some on the stain and wash off
RRxtar 08-16-2018 08:05 PM
Brakeclean
welfare 08-16-2018 08:27 PM
Oh you wanna remove gas, coolant, and oil stains from your driveway..
Nevermind then.
welfare 08-16-2018 08:28 PM
Purple power will take out just about anything
vitaminG 08-17-2018 02:51 AM
Ya I get the feeling he's not using enough elbow grease
murd0c 08-17-2018 08:26 AM
Rough Rider 2 degreaser is by far the best product to clean up oil and stained driveways and the odd thing is not many people know about it. You can buy it on the Chevron barge in coal harbour but no clue where else you can get it from.
Old Salty Rough Rider II
bcrdukes 08-17-2018 08:28 AM
LOL how the fuck is OP supposed to get to the Chevron barge? :lol
yray 08-17-2018 11:00 AM
doesn't have to be barge, just chevron marine stations
ones underneath the arthur laing
murd0c 08-17-2018 12:17 PM
steveston should have it as well
Bouncing Bettys 08-17-2018 12:38 PM
https://i.gifer.com/FOqs.gif
Hondaracer 08-17-2018 12:43 PM
Muriatic acid, however it’s so good that it may leave a mark where you used it instead of the oil
Also don’t kill/blind yourself using it
fliptuner 08-17-2018 12:52 PM
2500psi is enough but a tiny electric washer won't move enough volume
Hehe 08-17-2018 07:40 PM
Rent a gas powered pressure washer or hire a company that has one.
I've had oil stain on my family's properties, and nothing cannot be removed with commercial grade pressure washer.
syee 08-17-2018 08:32 PM
I've used this stuff on motor oil before. Seemed to do a pretty decent job (though it didn't get 100% of it out)
Oil Lift Oil Remover, 2-L | Canadian Tire
meme405 08-17-2018 10:34 PM
4000 psi and one of those pulsating nozzles. If the stain doesn't come out, you can just remove the top layer of concrete... lol
twitchyzero 08-18-2018 01:13 AM
are those safe for the average joe? it wont take out your eye/toe?
bcrdukes 08-18-2018 05:56 AM
Simple Green did work for me, but if the oil is penetrated into the concrete, it may not work. Some elbow grease and effort may be required to scrub it out.
Otherwise, try getting to the Chevron barge in Coal Harbour for the stuff murd0c recommended. :lol
