Old 08-16-2018, 10:44 AM   #1
BIC_BAWS's Avatar
Failed 180 Times in 78 Posts
How do gasoline, coolant, and engine oil stains from concrete driveway?
Error made in title: How do you remove gasoline, coolant, and engine oil stains from concrete driveway?
I'm using a 1600psi electric pressure washer and apparently just water doesn't work. . I tried using coca-cola, iron-off, and break clean. Break clean works wonders for the engine oil stains, but its not cost effective.
My strata is pretty lenient, but I think that gasoline stain was the last straw. The gasoline stain is the worst.
Another thread regarding prepping concrete floors used Muriatic Acid, and I might pick that up. Only issue is that it stains yellow. Any other recommendations?
Thanks!
Old 08-16-2018, 11:06 AM   #2
Bouncing Bettys's Avatar
Failed 496 Times in 162 Posts
Paint Thinner.
LEAFS!
Old 08-16-2018, 01:14 PM   #3
Failed 554 Times in 127 Posts
Try some super clean or other degreaser. Also try removing bmw to reduce oil stains
vitaminG is offline   Reply With Quote
Old 08-16-2018, 01:22 PM   #4
SFICC-03*
Failed 167 Times in 88 Posts
be careful using paint thinner on your driveway... if it's asphalt it may damage it.
Old 08-16-2018, 01:46 PM   #5
keifun's Avatar
Failed 25 Times in 14 Posts
I heard coca cola works Due to the carbonic and sulphuric acid in the soda
Surprised you said it doesn't work . Maybe need some more elbow grease .
Try acetone ?
keifun is online now   Reply With Quote
Old 08-16-2018, 01:52 PM   #6
Failed 5 Times in 2 Posts
Powdered laundry soap, stiff broom, water. scrub scrub scrub scrub. let dry, pour kitty litter on it, rub the kitty litter in with your feet, let it sit for a day or two. repeat.
nismodrifter is offline   Reply With Quote
Old 08-16-2018, 02:05 PM   #7
Failed 579 Times in 322 Posts
If nothing works just spot paint over the stains with some all weather matching grey paint.
Old 08-16-2018, 04:00 PM   #8
Excelsis's Avatar
Failed 680 Times in 181 Posts
degreaser and hot pressure washer optimally.. or 4000 psi regular pressure washer - 1600 psi isn't enough.
Excelsis is offline   Reply With Quote
Old 08-16-2018, 05:39 PM   #9
yray's Avatar
Failed 300 Times in 128 Posts
turtlewax car wash always took oil stains out from concrete
just pour some on the stain and wash off
dapperfied yraisis
dapperfied yray so waisis
FastAnna i really cant
Old 08-16-2018, 08:05 PM   #10
RRxtar's Avatar
Failed 205 Times in 120 Posts
Brakeclean
STRENGTHaesthetics
Old 08-16-2018, 08:27 PM   #11
welfare's Avatar
Failed 286 Times in 153 Posts
Oh you wanna remove gas, coolant, and oil stains from your driveway..
Nevermind then.
Gold is the money of kings;
-Norm Franz
Old 08-16-2018, 08:28 PM   #12
welfare's Avatar
Purple power will take out just about anything
-Norm Franz
Old 08-17-2018, 02:51 AM   #13
Ya I get the feeling he's not using enough elbow grease
Old 08-17-2018, 08:26 AM   #14
In RS I Trust
murd0c's Avatar
Rough Rider 2 degreaser is by far the best product to clean up oil and stained driveways and the odd thing is not many people know about it. You can buy it on the Chevron barge in coal harbour but no clue where else you can get it from.
Old Salty Rough Rider II
Old 08-17-2018, 08:28 AM   #15
LOL how the fuck is OP supposed to get to the Chevron barge?
Old 08-17-2018, 11:00 AM   #16
yray's Avatar
doesn't have to be barge, just chevron marine stations
ones underneath the arthur laing
dapperfied yraisis
Old 08-17-2018, 12:17 PM   #17
In RS I Trust
murd0c's Avatar
steveston should have it as well
Old 08-17-2018, 12:38 PM   #18
LEAFS!
Old 08-17-2018, 12:43 PM   #19
Muriatic acid, however it’s so good that it may leave a mark where you used it instead of the oil
Also don’t kill/blind yourself using it
Old 08-17-2018, 12:52 PM   #20
2500psi is enough but a tiny electric washer won't move enough volume
Old 08-17-2018, 07:40 PM   #21
Hehe's Avatar
Failed 685 Times in 223 Posts
Rent a gas powered pressure washer or hire a company that has one.
I've had oil stain on my family's properties, and nothing cannot be removed with commercial grade pressure washer.
Nothing for now
Old 08-17-2018, 08:32 PM   #22
I subscribe to the Revscene NWS thread(s)
Failed 11 Times in 6 Posts
I've used this stuff on motor oil before. Seemed to do a pretty decent job (though it didn't get 100% of it out)
Oil Lift Oil Remover, 2-L | Canadian Tire
syee is offline   Reply With Quote
Old 08-17-2018, 10:34 PM   #23
meme405's Avatar
Failed 409 Times in 181 Posts
4000 psi and one of those pulsating nozzles. If the stain doesn't come out, you can just remove the top layer of concrete... lol
Barney Fucking Purple FX35
Old 08-18-2018, 01:13 AM   #24
Failed 882 Times in 422 Posts
are those safe for the average joe? it wont take out your eye/toe?
Old 08-18-2018, 05:56 AM   #25
Simple Green did work for me, but if the oil is penetrated into the concrete, it may not work. Some elbow grease and effort may be required to scrub it out.
Otherwise, try getting to the Chevron barge in Coal Harbour for the stuff murd0c recommended.
