Old 08-18-2018, 06:44 AM   #26
BIC_BAWS's Avatar
Failed 180 Times in 78 Posts
Originally Posted by syee View Post
I've used this stuff on motor oil before. Seemed to do a pretty decent job (though it didn't get 100% of it out)
Oil Lift Oil Remover, 2-L | Canadian Tire
This is the stuff I used to clean up my garage actually. It didn't get everything out, so I'm going to need some stronger stuff.
Still got that massive gasoline stain though.
Old 08-20-2018, 01:04 PM   #27
I've used liquid dish soap with scrubbing to get out oil before, whatever you're using let it sit and work a bit before washing it off. You might need to do a few passes to get it all out too.
Old 08-24-2018, 06:59 AM   #28
matrixfwd's Avatar
Failed 51 Times in 8 Posts
how about the ones on TV , "30 seconds" thing or "CLR"
matrixfwd is offline   Reply With Quote
Old 08-24-2018, 07:27 AM   #29
Great68's Avatar
Failed 188 Times in 103 Posts
If it's bad I'll usually soak with undiluted degreaser, and scrub with a very stiff brush/steel brush.
But earlier this year I bought myself a 13HP pressure washer with a 14" whirl-a-way surface cleaner and it makes quick work of everything.
1968 Mustang Coupe
2008.5 Mazdaspeed 3
1997 GMC Sonoma ZR2
2014 F150 5.0L XTR 4x4
A vehicle for all occasions
